TwinTurbo.NET: Nissan 300ZX forum - The wastegate is PRE-SET to open when seeing a boost signal
Subject The wastegate is PRE-SET to open when seeing a boost signal
Posted by HighPsi (NorCal) on August 17, 2012 at 3:42 PM
  This message has been viewed 215 times.
In Reply To I known that, is it the knock sensor that triggers the ECU? posted by njz on August 17, 2012 at 03:05 PM
Message of about 6-7 psi, and a max of 9-10 psi of boost. When the factory boost solenoid is OPEN (12v signal) the actual boost signal is bled off through the solenoid into the intake tract.
